kz1300 banner
Electrical
Dual stator wiring
  • kennyb
  • kennyb's Avatar Topic Author
Dual stator wiring
11 years 4 months ago - 11 years 4 months ago
#5893
Just added a sub alternator to my A1. So do I need two regulators ?Or do you wire the extra stator into the existing voltage regulator? If so do you wire it to the stator out put AC side or out put DC side on the regulator? BTW The sub alternator was sourced from a Voyager 1300,thanks.
Last edit: 11 years 4 months ago by kennyb.
  • kennyb
Re: Dual stator wiring
#5969
Anyone?
  • RickG
  • RickG's Avatar
#5971
I have not ever fitted one but my thoughts are that a complete second system including regulator would be needed you couldn't hook them together because you might to have one feeding the other and end up with nothing where with a second system they both see a battery that needs charge or lights that need power and deliver it.
Z1300 A1 x 2
  • LareNurminen
  • LareNurminen's Avatar
#5972
If you have a service manual which covers the -82 model, you will have at the end the schematic which shows how Kawasaki did it.
My 82 has originally two alternators, both have their own reg/rec and they are connected to the main harness.
Hope this helps,
Lauri
  • trikebldr
  • trikebldr's Avatar
#5976
FWIW, the ZN1300 supplement manual show the two alternators, each with it's own rectifier/regulator, but the wiring harness connects the two together as Lauri said.
  • kennyb
#5977
Thanks people! Okay that's what I thought ;) Just wanted to be on the safe side before I created a firework show in my garage or between my legs at 70 mph :ohmy: Thanks
Moderators: scotch
Time to create page: 0.216 seconds
