kz1300 banner
what is the thread on ?
  • bobber-edd
  • bobber-edd's Avatar Topic Author
  • Premium Member
  • Premium Member
11 years 3 months ago
#6479
what is the thread on the prop shaft nut on the engine left or right thread ??as it will not come off even after hiring a formula 1 air gun which i could hardly lift !! :angry:
zed 13 1979 A1 model
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
Re: what is the thread on ?
#6480
Are you talking about the 4 bolts that connect the drive shaft to the engine? If so, they normal threads, but loc-tighted on from the factory. I ended up using my normal ratchet wrench with a 4-foot pole to give me the leverage to break them loose.
The following user(s) said Thank You: bobber-edd
  • bobber-edd
  • Premium Member
  • Premium Member
#6481
yes ive got the 4 bolts out with my impact gun no problem its the big 27 mm nut im on about ??
  • Lucien-Harpress
#6482
The one in the middle of the Output shaft? Normal thread, by the looks of it. Official procedure (out of the manual) is to take out the whole assembly (it's only a few inches long), hold it using a vice and a special adapter that bolts on to the four output shaft bolts, and lever it off with a long-handled wrench/ratchet.
To get the entire assembly out, though, you have to split the cases. What are you trying to do (for curious)?
  • bobber-edd
  • Premium Member
  • Premium Member
#6671
only to replace the cork type gasket
  • stocktoy
  • stocktoy's Avatar
#6676
Have you tried to pull the plate back a bit and then wrap a couple of turns fo string aor twine around the outside of the 4 bolts andthen tighten the plate back up (this has worked for me on a couple of 5 ton truck diff's when I was in a pinch and rush equip not making money if in shop said the boss to the guy trying to =keep things going) Long time ago in a shop far far away...
Moderators: scotch
Time to create page: 0.173 seconds
