- Thank you received: 25
Engine storage?
- McZed
- Elite Member
10 years 11 months ago #7770
by McZed
Z1300 UK
Engine storage? was created by McZed
I have come into possession of a complete 1300 engine; I couldn’t refuse at the price I was offered it for.
I don’t really need it at the moment, my big old Z is running pretty sweetly for now, but you never know with a 35 year old engine. So my problem is this. What would be the best way to store the spare engine? Do I strip it down and store the parts, or am I better to leave it in one piece. Any advice would be gratefully received.
Z1300 UK
- KZQ
- Administrator
- Thank you received: 340
10 years 11 months ago - 10 years 11 months ago #7771
by KZQ
Replied by KZQ on topic Engine storage?
Hi MZ,
I'd drain the carbs and squirt some oil in the plug holes. Alternately, you could mount it on a stand, get it to run and put it on display in my family room. :woohoo:
The choice is yours.
Bill
Bill
Last edit: 10 years 11 months ago by KZQ.
- Kawboy
- Thank you received: 1198
10 years 11 months ago - 10 years 11 months ago #7774
by Kawboy
Replied by Kawboy on topic Engine storage?
Lets not forget to dump the crankcase oil and if it was me, I'd put in fresh oil. Used engine oil has acids in it from the combustion process and of course there's additives in the oil to neutralize them but for the purposes of long term storage, it's always best to store it with fresh oil. Also remember that there's also additives in the engine oil to keep the seals soft so they will do their job.
Had a second thought. While your dumping the crankcase oil don't forget to empty out the oil filter housing. You could reassemble it without a filter, but if you do, tag the engine to remind yourself that there's no filter in it.
Last edit: 10 years 11 months ago by Kawboy.
- Lucien-Harpress
- Thank you received: 99
10 years 11 months ago #7775
by Lucien-Harpress
Replied by Lucien-Harpress on topic Engine storage?
Plug the intake and exhaust ports. WELL. Most cylinders should be fine, but there will always be one or two with a valve open. Get ANY kind of moisture in there, and that cylinder is toast (found that out the hard way on what I thought was a good donor engine).
It helps if you turn the motor over a couple times on a semi-regular basis, to keep everything free and moving.
Moderators: scotch
Time to create page: 0.119 seconds
