kz1300 banner
piston rings?
  • kennyb
  • kennyb's Avatar Topic Author
piston rings?
10 years 11 months ago
#7779
I need piston rings and I heard from the shop that did my work that KZ650 piston rings might work?
  • Kawboy
  • Kawboy's Avatar
Re: piston rings?
#7780
Same bore size for sure. I've read that the pistons are nearly identical. Slight difference in crown shape. I would imagine that the ring thickness would be the same. You'll want to verify that the upper ring has a chromium face, the second ring should be cast iron. Definitely worth sticking your neck out and buying a set.
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
Re: piston rings?
#7781
I think the KZ650 rings are a bit wider than stock rings. They can work, but the piston will need to be milled to accept them.
Stock piston rings are still available from Kawasaki. A bit pricey at about $50 a set, but you can still get them pretty easy.
  • Kawboy
  • Kawboy's Avatar
Re: piston rings?
#7784
Pulled this info from the www.KZ650info.com site
"The stock 650 rings have thicknesses as follows : 1.2mm (top) 1.2mm (2nd) 2.5mm (oil)"
  • aus_z1300
  • aus_z1300's Avatar
  • Elite Member
  • Elite Member
Re: piston rings?
10 years 11 months ago - 10 years 11 months ago
#7785
There was a post on here a few weeks back where he machined a larger groove to accommodate the 650 rings but i can't remember who it was.
Here it is found it.
rings
Last edit: 10 years 11 months ago by aus_z1300.
Moderators: scotch
Time to create page: 0.166 seconds
