kz1300 banner
Sump / oil pan.
  • McZed
  • McZed's Avatar Topic Author
  • Elite Member
  • Elite Member
Sump / oil pan.
10 years 11 months ago
#7782
I’ve been looking at the shiny new engine I bought (maybe not so shiny, or new) and it has got me thinking. The sump on it is the later large capacity item. Is it possible to swap the sump without removing the engine?
Or would I be better to leave well alone.
Z1300 UK
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
Re: Sump / oil pan.
#7783
Perfectly doable. Exhaust is going to have to go away, which might be interesting. The hardest part will be getting the oil pickup off- it's held on by Philips screws, and I almost guarantee you'll need an impact to get it off. The angle doesn't help any. But, that being said, you CAN drop the pan while the motor is in-frame.
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Sump / oil pan.
#7789
I've done this a couple of times. As Lucien says, the exhaust system needs to come off.
As for removing the oil pick-up - I've always managed with using an impact driver with a JIS bit (otherwise make sure it's a really tight fitting bit) and then turning the impact driver by hand. I've never had to impact it with a hammer.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • Kawboy
  • Kawboy's Avatar
Re: Sump / oil pan.
#7796
ah yes, my favorite screws , Japanese Industrial standard JIS screws.
  • zed_thirteen
Re: Sump / oil pan.
#7798
I bought a pair of JIS P1 and P2 drivers a few weeks back to take the butterflies out of my carbs. I was very surprised by just how solidly locked in they felt in the screw heads.
Normally, when using Philips drivers, I think I have to exert as much force pushing down on the driver as I do rotating the driver. just had to rotate the JIS drivers and I didn't once get the feeling they were going to cam-out.
I will never use Philips drivers on my bikes again.
1980 CBX1000-A
1990 ZZ-R1100 C1
Moderators: scotch
Time to create page: 0.181 seconds
