kz1300 banner
Valve Cover Baffles
  • kz1300texas
  • kz1300texas's Avatar Topic Author
  • Junior Member
  • Junior Member
Valve Cover Baffles
10 years 10 months ago
#8224
I recently purchased a KZ 1300, the valve cover baffles are removed and replaced with a closed plate. Will this hurt or help performance??
  • Craig
  • Craig's Avatar
Re: Valve Cover Baffles
10 years 10 months ago - 10 years 10 months ago
#8227
They are/were merely 'environmental friendly' emission ports and won't affect performance or hurt the motor. Having them blanked off is common to a lot of KZ owners.
Last edit: 10 years 10 months ago by Craig.
  • Kawboy
  • Kawboy's Avatar
#8232
The Canadian version uses the same casting but the bore of the tube where the hose attaches is not bored out and there's no reed valve under the cover, so the Canadian baffle cover acts like a plate covering the hole in the valve cover.This Eliminated making a different casting for the valve cover.
Bottom line go ahead and remove the baffle plate and associated hoses if that's your desire. Block off the port where the hose enters the air box. And you'll need to machine up cover plates to install in place of the baffle covers.
Moderators: scotch
Time to create page: 0.164 seconds
