kz1300 banner
CB750 Rings
  • kza13
  • kza13's Avatar Topic Author
CB750 Rings
12 years 6 months ago
#676
I remember seeing something mentioned here about using CB750 rings in the 13, I was looking thru some of my old paperwork on the 13, a lot of it was owned by a mate of mine who passed away from cancer, he bought a 79 model and kept it going for many many years, and he was kind enough to leave me the spare bike and a lot of bits and pieces, anyway in one of the manuals he does mention using CB750 rings, they are 61mm, and a one piece oil ring, so I guess next time I do a re-build i'll buy some of those, checking the prices they are a lot cheaper than 1300 rings even though you have to buy 2 x 4 cylinder kits, cheers all
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
  • strate6
  • strate6's Avatar
Re: CB750 Rings
#677
It would be useful to find another bike to use rings from as the 1300 rings are expensive.
My understanding is the standard 1300 had a 62mm bore ?
Is that correct?
Pete F
  • zoso
  • zoso's Avatar
  • Premium Member
  • Premium Member
Re: CB750 Rings
#679
The z1300 definitely has a 62mm bore.
cheers
  • kza13
Re: CB750 Rings
#685
so perhaps he used oversize rings ??, the note didn't mention that, have to check it out some more, no worries, cheers
  • strate6
  • strate6's Avatar
Re: CB750 Rings
#690
That could well be the case as if he used 4th oversize CB750 rings they would be 1mm larger than 61mm making them 62mm, same size as 1300 standard rings.
Pete F
  • kza13
Re: CB750 Rings
#699
Yep your right, wonder how prices compare ??
quote from a website:-
Big Bore kits for 750 4's
Nothing replaces displacement but even more displacement
But bear in mind that it's the cam that is the key to an engine's performance characteristics. And, in the quest for power, it's the overall combination of all factors that result in the power output.
Bore (mm) Displacement (cc)
61.00 (stock) 736
61.25 (1st oversize) 742
61.50 (2nd oversize) 749
61.75 (3rd oversize) 755
62.00 (4th oversize) 761
64.00 812
64.50 823
65.00 836
67.00 895
67.50 915
70.00 970
73.00 1060
Moderators: scotch
Time to create page: 0.162 seconds
