kz1300 banner
spark plug fouling
  • paulb
  • Topic Author
  • Elite Member
  • Elite Member
10 years 7 months ago #10032 by paulb
spark plug fouling was created by paulb
Hi guys
i have managed to foul a couple of my iridium spark plugs any ideas how to clean them without damaging them, also does anybody still gap plugs or is that a thing of the past
many thanks
Paul
10 years 7 months ago #10035 by kza13
Replied by kza13 on topic spark plug fouling
yeh couple of my iridiums were fouled, gave them a rub with a wire brush and blew on them, all good, heck I ain't gentle, how else do you get the build up off ??
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
10 years 7 months ago #10036 by aus_z1300
Replied by aus_z1300 on topic spark plug fouling
I have heard of people using aerostart or start ya bastard .
I use bosch or champion plugs they recover from being run rich . For some reason ngk don't maybe it helps sales.
10 years 7 months ago - 10 years 7 months ago #10039 by Kawboy
Replied by Kawboy on topic spark plug fouling
You can spray them down with ether or mass air flow sensor cleaner or brake cleaning fluid. Either one will wash off any oil residue. Carb cleaner and throttle body cleaner have a slight lubricant in them so I wouldn't use either of these.
Last edit: 10 years 7 months ago by Kawboy.
10 years 7 months ago #10041 by trikebldr
Replied by trikebldr on topic spark plug fouling
If you want to get them clean as new, soak them for five minutes in benzene! Benzene removes all carbon!
No, I won't divulge my source of benzene.
10 years 6 months ago #10080 by scotch
Replied by scotch on topic spark plug fouling
Do not use a wire-wheel to clean the plugs. You run the risk of embedding metallic particles on/into the insulator and that with cause them to short rather then "spark". I don't use a wire brush either, but there's less likelihood of the shorting issue in that case.
Now Benzene ! Got to get me some of that.
And for those waiting for it: I soak mine in Lacquer Thinner and it works on the dirtiest and is readily available without alerting "Homeland Security" !
What I will use to clean down deep after a soaking in L.T. is the smallest of a set of those cheap "jewellers" screw-drivers - a flat one. It will get all the way down, scraps the crud adequately and won't harm the insulator.
Always High - Know Fear !
Moderators: scotch
Time to create page: 0.109 seconds
