kz1300 banner
Ticking Noise
  • Yaegunp
  • Yaegunp's Avatar Topic Author
  • Elite Member
  • Elite Member
Ticking Noise
9 years 10 months ago - 9 years 10 months ago
#13890
I have been trying to diagnose a ticking noise in the motor - some may call it the 'sewing machine noise'. I have all but discounted the cam chain tensioner (it's manual). I read on another site it can be caused by aerated oil??
The noise doesn't start until near operating temperature or there-abouts and gets faster with more speed. I can actually hear the noise with helmet on at all speeds. I thought it might have been a badly seated tacho cable but I have discounted that theory also.
Does anyone have any clues?? Maybe I have got the bike running so good that I'm hearing just the normal sound of the Z1300 :woohoo: But I doubt it!
PS. I re-shimmed it about 5 months ago and I'm hoping the noise is not shims out-of-spec. The process of re-shimming was very calculated and methodical. But I guess I'll have to check that again if all else fails.
1983 Z1300 A5 plus Sidecar.
Last edit: 9 years 10 months ago by Yaegunp. Reason: ps
  • strate6
  • strate6's Avatar
Re: Ticking Noise
#13891
Its pretty much a needle in a hay-stack until you can at least find the approximate area the tick is coming from.
Once we have that we can begin to home in.........but other than that all I can say is the noise is coming from the bike somewhere !
Pete F
UK
  • Tyler
  • Tyler's Avatar
  • Elite Member
  • Elite Member
Re: Ticking Noise
#13892
I observe the same thing in my bike, a light tick after 15 to 20 minutes of driving. This I think is normal, possibly related to the timing chain, though it could be the cam chain but it matters not. If you have driven an air cooled Kawasaki of the same vintage... the 1300 runs quiet as a mouse next to the rattle, ticks, knocks of air cooled 4's.
1981 KZ1300
  • Yaegunp
  • Elite Member
  • Elite Member
Re: Ticking Noise
#13893
strate6 wrote: Its pretty much a needle in a hay-stack until you can at least find the approximate area the tick is coming from.
Pete F
UK
Point taken strate6, my bad. :blush: I have had my home made stethoscope (a wooden stick and a cup) all over it without being able to narrow the noise down to an exact spot. I used that method to hunt down my starter motor clutch problems and the primary/secondary chain noise with great success. However, I seem to do better with just my ear with this noise, and I can tell you that it is coming from approximately the top right hand side of the engine, somewhere around number 4 spark plug. That's why I thought it may have been the tacho cable at one point.
  • kwak1261
  • kwak1261's Avatar
Re: Ticking Noise
#13894
is the spark plug loose ? maybe when it warms up or slight blow on zorst gasket ?
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • McZed
  • McZed's Avatar
  • Elite Member
  • Elite Member
Re: Ticking Noise
#13896
If it makes the noise at tick-over, try pulling in the clutch to see if it goes away. The clutch on mine is a bit noisy when it's hot.
Z1300 UK
Moderators: scotch
Time to create page: 0.194 seconds
