kz1300 banner
Ticking Noise
  • Yaegunp
  • Yaegunp's Avatar Topic Author
  • Elite Member
  • Elite Member
Re: Ticking Noise
9 years 10 months ago
#13937
hillsy wrote: Double check it's not a leaking exhaust header gasket first up.
I put new gaskets in not long ago (aluminum) and I re-tightened all nuts yesterday hoping it might have been the problem but alas, no!
1983 Z1300 A5 plus Sidecar.
  • hillsy
  • hillsy's Avatar
  • Premium Member
  • Premium Member
Re: Ticking Noise
#13939
What about the Kleen ports? Do you have that system (IE: are you in the US?). Maybe that's playing up? Worth looking at before you start digging deeper.
  • hillsy
  • hillsy's Avatar
  • Premium Member
  • Premium Member
Re: Ticking Noise
#13940
Never mind - I see you're in Oz.....
The following user(s) said Thank You: Yaegunp
  • Yaegunp
  • Elite Member
  • Elite Member
Re: Ticking Noise
#13942
After bringing the bike up to maximum operating temperature I measured the temp/heat on all exhausts just behind the radiator and 5 of them were in the 90-100 degrees Celsius region and 1 was 60-70 degrees, which is number 4. I then did a compression test with the engine hot and here are the results
No. 1 - 140psi
No. 2 - 150psi
No. 3 - 140psi
No. 4 - 150psi - (Yes that is correct)
No. 5 - 150psi
No. 6 - 150psi
No. 4 is where the noise is coming from, if I was to guess, around the shim and bucket area.
I will be removing the valve cover today I just hate removing those infernal ignition coils (me and them don't get along at all)
  • hillsy
  • hillsy's Avatar
  • Premium Member
  • Premium Member
Re: Ticking Noise
#13943
Maybe it has spat out the shim?
Hopefully it hasn't done too much damage if that is the case.....
  • Yaegunp
  • Elite Member
  • Elite Member
Re: Ticking Noise
9 years 10 months ago - 9 years 10 months ago
#13944
hillsy wrote: Maybe it has spat out the shim?
I knew it!! Shims are all in place. Cam chain looks fine and the sprocket has plenty of depth on the teeth, some slight wear from the chain is all. It does seem a little tight though and remember I am quite the novice so I don't really have a clue. The location of the noise doesn't match with the cam chain either.
The diagnosis seems to point one way and then the other. Just once I would like to get one of the easy ones :blink:
PS. Will post video later on with valve cover off.
Last edit: 9 years 10 months ago by Yaegunp.
Moderators: scotch
Time to create page: 0.169 seconds
