Running at idle for a long time
- Yaegunp
- Elite Member
9 years 10 months ago
Will running the engine at idle for a long time have a tendency to foul the spark plugs?
1983 Z1300 A5 plus Sidecar.
- strate6
Re: Running at idle for a long time
If your mixture settings are "around" the correct levels and no issues with the chokes or float heights............then NO, running on idle for any period should not foul plugs.
It is always best to be on the richer than the leaner side with and carb 1300.
Pete F
UK
Pete F
UK
The following user(s) said Thank You: Yaegunp
- Ledkz1300
What he said ^
I was fouling mine at idle and low rpm constantly but once I had the mixture screws dialed in I've been good ever since.
Moderators: scotch
Time to create page: 0.185 seconds
