kz1300 banner
Radiator coolant hoses - urgent help needed
  • Fraserc
  • Fraserc's Avatar Topic Author
  • Junior Member
  • Junior Member
9 years 9 months ago
#14298
Can anyone advise where to get replacement radiator hoses in the UK. The top one on my 1979 A1 has a split. Someone said that there are silicone ones available but I need a spec or some information.
Was hoping to get my bike on the road for the weekend and a local show, but now struggling.
Appreciate any suggestions.
  • charlie9670
  • charlie9670's Avatar
  • Elite Member
  • Elite Member
Re: Radiator coolant hoses - urgent help needed
#14300
A trip to your local motor factors with the offending hose may be worth trying, if they are helpfull there should be one that can be cut to size.
:) Z13 UK
The following user(s) said Thank You: Fraserc
  • zoso
  • zoso's Avatar
  • Premium Member
  • Premium Member
#14301
You can get them on ebay - silicone radiator hose 32mm diameter.
  • scotch
  • scotch's Avatar
#14309
re: Radiator Hose.
GOODYEAR #61028 will provide both top and bottom hoses from this one hose. For the upper simply align and cut the required length and bend.
bar code: 0 37256 02401 6
Always High - Know Fear !
  • Phil
  • Phil's Avatar
#14313
I bought some silicone hose of the correct diameter & cut it to length. One was straight & the other was a pre-formed 45 degree bend.
Moderators: scotch
Time to create page: 0.171 seconds
