kz1300 banner
Camshafts - Differences between Carb and Injected?
  • Yaegunp
  • Yaegunp's Avatar Topic Author
  • Elite Member
  • Elite Member
9 years 8 months ago
#14629
I ordered a second hand pair of cams from Ebay as mine have had the hardened surface damaged. Sadly they have gone missing in transit so I have to source another set. My knowledge about them cams is there are 3 models - carb, injected, and another for the Voyager?
Does anyone know if they are interchangeable or does each model have different specs?
1983 Z1300 A5 plus Sidecar.
  • Kawboy
  • Kawboy's Avatar
Re: Camshafts - Differences between Carb and Injected?
#14637
The carb engines have more agressive cams. Intake is 270 deg. duration and exhaust is 280 deg. duration.
The DFI engines have 260 duration cams both intake and exhaust.
Not sure if they are interchangable (physically). The suppliment for the ZN says to refer to the KZ1300 service manual for info, so I'll assume that if the suppliment doesn't identify a different lift then the valve lift for both are the same. Maybe one of the other members can verify??
The following user(s) said Thank You: Yaegunp
  • Phil
  • Phil's Avatar
#14653
I was always under the impression that the ZG1300 (DFI) cams had more duration, which is what gave the (alledged) extra 10 bhp (taking it to 130 bhp)?
The ZN1300 (Voyager) made about 117 bhp from memory as they retuned it again for more midrange as it was a tourer, don't know if their cams are unique, or they retuned them in some other way?
  • tackelhappy
  • tackelhappy's Avatar
#14654
All three bikes I checked-1980 USA edition, 1986 Voyager and 1986 Zg 1300 united kingdom edition all have different part numbers.
So it maybe just the profile on all three that is different ?
OKANAGAN FALLS. BC ,Canada
  • Phil
  • Phil's Avatar
#14658
tackelhappy wrote: All three bikes I checked-1980 USA edition, 1986 Voyager and 1986 Zg 1300 united kingdom edition all have different part numbers.
Yes that's maybe how they varied the power outputs, purely by different cam profiles.
  • Yaegunp
  • Elite Member
  • Elite Member
#14661
This is some info from a Z1300 'guru' in Sweden who has been kind enough to help me out. I include it here for others to ponder.
And for you´r last question then, I have no numbers in my head for the moment but the differense between the cams are lift/height and "durance", (not sure what the english word is), eg: the length/time the valve is open.
I have never heard of anyone in the world who has tried to interchange cams between the models, (as i said earlier about my project to try to put carbcams into my injected Voyager) so i can´t say nothing about what will happen...
THOUGH....( again there are just 3 types: carbs, injected and Voygager cams), there are more/higher lift on the injected cams regarding carb ones. Voyagers ones are ludacris and almost useless,(thats why i wan´t to change on my bike).
So, as i said, i never heard of anyone changed them, so i can´t say what will happen if you put injected cams into a carb bike. There are a risk for total failiure if the valves would reach the piston. Remember that both pistons and head are NOT the same on the carb and injected models. So to be sure, just be sure you got carbcams Paul!
(In my case, i´m going at the other direction...i´m going from Voyagers even higher lift to the carbs lowest camlift...so i will be safe).
The following user(s) said Thank You: dogfight
Moderators: scotch
Time to create page: 0.163 seconds
