Stator rubber grommet
- Mrnlaguna
- Junior Member
12 years 5 months ago
Good Morning Sixer's Does anyone have a source for the rubber grommet that seals the three yellow wires coming through the case cover from the stator? Mine continues to leak oil even after a thorough cleaning of the wires and the grommet with MEK then a new gasket and liberal amounts of black high temp silicone.
Thanks, Mike
Thanks, Mike
- strate6
Re: Stator rubber grommet
Hello mate.
MCG DE Z1300 Germany sell them.
Pete F
Pete F
The following user(s) said Thank You: Mrnlaguna
- Mrnlaguna
- Junior Member
Thanks Pete, a life saver you are! been scratchin' my head thinking I'd make one or modify one from another bike, don't want to be slip sliding in my own oil.......or anyone else's for that matter, thanks again, Mike
- KZQ
- Administrator
Hi Mike, The grommet you're struggling with is always tough to seal. As you've described getting the oil off of the old grommet and wiring is critical. I've been using Hondabond HT with great results even with an old failed grommet.
Hope this helps.
Bill
Hope this helps.
Bill
- Mrnlaguna
- Junior Member
12 years 4 months ago
Thanks Bill, where would we be without Honda,Yamaha,Kawasaki or good old Three Bond! Need to order some on line as I am also building a 72' H2 motor. Used black RTV on the big six's stator grommet after a good de-grease and clean, lasted about a week......back to the drip!
- Mrnlaguna
- Junior Member
11 years 8 months ago
Hey Pete, Mike here, it's been a while since you sent me the info on the Stator wire grommet for the 1300. Do you have any other info on MCG De 1300 in Germany, can't seem to pull them up on my computer, tried re-sealing with no luck.
Thanks, Mike
Thanks, Mike
Moderators: scotch
