kz1300 banner
Cylinder block base o-rings
  • Kwakanuk
  • Kwakanuk's Avatar Topic Author
  • Senior Member
  • Senior Member
9 years 3 months ago
#15771
Hey guys,
I'm about to install the cylinder block on crank case. According to partzilla cylinder block diagram it shows o-rings of 67mm and 67.5 mm on the underside of cyl. bl . I do have a set of red o-rings that came with my complete gasket set. The thing is that I can't find anywhere in the service manual any mention of these o-rings. Also I kind of find it a bit odd to install o-ring in that location.
I would appreciate any pointers on that issue.
Thanks
Keep on sixing!
Gpz 750 Turbo 1984, Gpz 750 Turbo 1985, KZ 1300 1981.
  • LareNurminen
  • LareNurminen's Avatar
Re: Cylinder block base o-rings
#15773
Those O-rings seal the cylinder sleeve (steel) to the cylinder block (aluminium)
If you have not pulled the sleeves there in normally no need for them.
  • Kwakanuk
  • Senior Member
  • Senior Member
#15778
Thanks for the quick response. It makes a lot of sense, now.
Moderators: scotch
