kz1300 banner
ZN1300 False neutral light indication
  • Bucko
  • Bucko's Avatar Topic Author
8 years 8 months ago
#16887
Getting a neutral light indication when I'm searching for neutral and find that even though the neutral light is on, I'm not really in neutral. It's a bit unnerving. Anyone else experience this" and if so, what's the fix. Thanks for any advice.
  • Neville
  • Neville's Avatar
Re: ZN1300 False neutral light indication
#16906
I have experienced this on my Z1300 A1 as well - not sure if the electrical circuit is the same as the ZN but my symptoms were that the neutral light came on once the oil had warmed up and was on all the time when the engine was hot. I discovered that there was a short circuit from the neutral sensor "pin" to the body of the sensor. This seemed to be caused by a build up of grime and oil at the base of the pin that the neutral wire connects to. Hope your fix is as simple as mine was...
I bought a new neutral sensor (its a simple spring loaded plunger switch) but did not have to fit it - the cover needs removing to do this properly which means draining the oil and replacing the gasket.
  • Bucko
#16907
Thanks for your note Neville. I don't think my case is a short as the light doesn't come on randomly, only when I'm stopped and light tapping up or down to go into neutral. It seems as if the switch is out of adjustment although I suspect it's not adjustable - need to review the service manual to check.
Moderators: scotch
Time to create page: 0.165 seconds
