kz1300 banner
Head valve removal/spring compression tool
  • StanG
  • StanG's Avatar Topic Author
  • Banned
  • Banned
8 years 10 months ago
#16984
I couldn't find searching the forum so here is a direct question.
Internet offers a bunch of spring compression tools, but I just don't know which one would work. Any suggestions?
  • StanG
  • Banned
  • Banned
Re: Head valve removal/spring compression tool
#16985
  • Kawboy
  • Kawboy's Avatar
#16987
No eBay APP ID and/or Cert ID defined in Kunena configurationYou will probably be happy with this one.
I modified a 12" C clamp with a machined piece similar to what's on the end of the listed tool above. It's crude but got the job done.
"Necessity is the Mother of Invention"
  • Kawboy
  • Kawboy's Avatar
#16988
Kawboy wrote: You will probably be happy with this one.
Hmmmmm Can't Edit the post??? Wasup KZQ???
VALVE SPRING COMPRESSOR PINCER 10" TOOL ENGINE LIFTER SPRINGS RETAINER VALVE - This is what I was trying to add to the post. For some reason it didn't like cutting and pasting the htps line. ???
  • StanG
  • Banned
  • Banned
#16990
Yes... I can't find the 'edit' my post as well. I had to rewrite my posts and actually just scrap a few and a bunch of photos and it says I have no access to one of them. That's on the side note.
I will search for the one you suggest. I just spent another hour cleaning the head and I am sooo ready to pull the valves. And just now I was blow drying the head after a shower in hot water.
I might take a 1.5 inch ling piece of pipe and cut it in similar way, then use a clamp. Of course I will update about the progress.
  • Bucko
  • Bucko's Avatar
8 years 10 months ago - 8 years 10 months ago
#17113
Go for the 'Plunger' style tool, it's way faster than the "C-clamp' method.
www.amazon.ca/Lisle-36050-Keeper-Remover...taller/dp/B0012S61IO
Last edit: 8 years 10 months ago by Bucko.
Moderators: scotch
Time to create page: 0.167 seconds
