kz1300 banner
Spin-on adapter/Cooler
  • scotch
  • scotch's Avatar Topic Author
8 years 4 weeks ago
#19852
To answer a polite P.M. question/concern - thanks for that ! And for the record - I have no problem answering questions in the Forum, about anything I've posted:
Yes, the WIX spin-on oil filter IS smaller then the stock oil-filter cartridge. Filter mediums have improved over 38 years and WIX is noted as one of the better quality filters.
The WIX application chart shows: Principle Application: Ford Probe (89-97), Mazda (83-96), Kia Sportage (95-02), Polaris ATVs. This filter is also the same physical size as the oil filter on a '80 3.1liter V8 Turbo Trans AM that I once owned. That filter was sandwiched between the exhaust manifold and the engine block !
Yes - the upper cross-brace on the center-stand must either be removed or partially "relieved" to fit around the filter. This is solely dependant on the retracted position of the individuals center-stand. Conversely, the center-stand "Stop" could be adjusted to keep it slightly lower, thus no mods to the C.-stand would be needed.
The "Adapter" stays on the bike (permanently for the purposes of this question). The filter simply spins on or off as with any similar type.
Always High - Know Fear !
  • usakz1300
  • usakz1300's Avatar
  • Premium Member
  • Premium Member
Re: Spin-on adapter/Cooler
8 years 4 weeks ago
#19867
WIX filters are considered to be the best oil and fuel filters on the market. WIX also makes a lot of the better quality brand name parts store filters as well.
STAY COMPLETELY AWAY FROM FRAM, WITH THEM, YOU WILL LOSE OIL PRESSURE.
The following user(s) said Thank You: scotch, Kawboy, StanG
Moderators: scotch
Time to create page: 0.159 seconds
