Spacer instead of deep sump?
- Broes
- New Member
7 years 11 months ago - 7 years 11 months ago
When I searched this forum for more information I couldn't find any post of anyone who fitted a spacer instead of a deep sump.
I searched the internet for a deep sump but could not find anything
Therefore I found a spacer as a alternative at
1300 Kawasaki South Africa
. Besides that he also makes a lot of other interesting stuff like custom swingarms which fit wider wheels. As I mentioned there were a few topics where the spacer is mentioned but no one has actually fitted one. Is this still the case?
I contacted the seller and considering to buy (after my bank account allows it;)) a spacer and a custom exhaust from him so I know for sure that it will fit together. Any other tips or tricks?
Last edit: 7 years 11 months ago by Broes.
- scotch
Re: Spacer instead of deep sump?
I can't fit a Deep Sump due to lack of adequate space. I only have about 3/4" space between the DG collector and the bottom of the stock sump. That's the reason I used "Header-Wrap" on the collector. I have mentioned this before several times and no one has contradicted this close fit so don't know whether it's unique to me and the way I have the down-pipes angled. Having said that, there's no "wriggle" room once all 6 pipes are in the collector. The geometry of the down-pipes fixes the collector into a position that only gives me that 3/4".
I've never seen a Deep-Sump on EBay or anywhere else. I do recall seeing the "spacer" a long time ago but it wasn't on EBay. I would want to confirm with a quick email that the combination of exhaust and spacer will work - definitively ! Doesn't make sense that they'd sell you the two otherwise, but why take the chance on an assumption. Once confirmed - go for it !
No tips or tricks at this moment.
Always High - Know Fear !
Last edit: 7 years 11 months ago by scotch.
Moderators: scotch
Time to create page: 0.163 seconds
