kz1300 banner
Bottom End Bearings
  • Bob4717
  • Bob4717's Avatar Topic Author
  • Junior Member
  • Junior Member
Bottom End Bearings
12 years 7 months ago
#1613
Hi, I need some advice from the experts on this forum: My project is a 1979 1300. I bought it completely disassembled and have just about gathered up most of the parts that were missing. The engine was in boxes. The question I have is this- when it was taken apart the person I got it from had pulled out all the bottom end bearing shells and put them in a bag. I see no issues at all with the crank, but I always believed that if you were going to reuse the bearings they should be put back exactly where they came from. Should I use the old bearings or buy all new ones? Could good used bearings work in any of the crank journals? Thanks in advance for your help....Bob
  • kza13
  • kza13's Avatar
Re: Bottom End Bearings
#1615
If your going to re-build it right, put new in, I did the rings on mine after the end of the secondary shaft wore out, had to find new cases, so while I had it apart that far I just put new bearings in, at least then I know they are right, just my opinion, cheers
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
The following user(s) said Thank You: Bob4717
  • RickG
  • RickG's Avatar
#1616
There is nothing wrong with using old bearing shells but you have to be sure the clearances are right and the way to do that is plasti gauge. There is a section in the factory manual about using it.
Z1300 A1 x 2
Moderators: scotch
Time to create page: 0.159 seconds
