Impeller circlip
- zed_thirteen
Impeller circlip
7 years 3 months ago
Anyone have a good method to hold the impeller against the spring of the mechanical seal while the circlip is installed?
I lost my circlip to a parallel universe over the weekend and have ordered another 10 (I still have another 9 somewhere from the last time I did this job but ordering more was easier than searching for my spares!)
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- strate6
Re: Impeller circlip
Long time since I did a replacement pump seal but seem to recall using a pair of long pointy nose pliers opened to press against the impeller whilst you position the clip with circlip pliers ?
Dont forget the O'Ring on the shaft behind the clip itself !!
Pete
UK
Pete
UK
- scotch
It can be tricky but as pointed out, some method of pushing the impellor back against the mechanical-seal spring is required to get the cir-clip groove exposed. I've also used a pair of pliers (spread open) to do this.
Always High - Know Fear !
- Frank833
- Elite Member
7 years 3 months agozed_thirteen wrote: ... have ordered another 10 (I still have another 9 somewhere from the last time I did this job but ordering more was easier than searching for my spares!)
Brother from another Mother!
- Bucko
7 years 3 months agozed_thirteen wrote: . (I still have another 9 somewhere from the last time I did this job but ordering more was easier than searching for my spares!)
Very familiar with that scenario.
- StanG
- Banned
Bucko, I'd be up for a couple if you find them. Cheers.
Moderators: scotch
Time to create page: 0.190 seconds
