SPARK PLUGS ?
- zoso
Re: SPARK PLUGS ?
12 years 3 months ago
I've been using NGK BPR5EIX in both bikes for over a year - no problems.
- kza13
Re: SPARK PLUGS ?
whats the difference between BPR6EIX-11 and BPR6EIX ? and what gap are you using ?, just wondering, e-bay has a set for a 6 cylinder car with free postage so might get them, cheers
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
- Toddh
Re: SPARK PLUGS ?
12 years 3 months agokza13 wrote: whats the difference between BPR6EIX-11 and BPR6EIX ? and what gap are you using ?, just wondering, e-bay has a set for a 6 cylinder car with free postage so might get them, cheers
Here is the breakdown:
B - Thread Size / Hex Size: 14 mm / 13/16" (20.8 mm)
P - Construction: Projected Insulator Type
R - Resistor
Heat Rating Numbers : 6
E - Thread Reach: 19 mm (3/4")
NGK Standard Resistor Green Plugs : BPR6E
Standard Non Resistor Plug : BP6ES
Standard Resistor Plug : BPR6ES
Standard Green Plug : BP6E
Iridium IX : BPR6EIX
Iridium MAX : BPR6EIX-P
Premium RX :
The suffix or -11 is the Gap which equates to 1.1mm or .044"
Regards.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- strate6
Re: SPARK PLUGS ?
12 years 3 months ago - 12 years 3 months ago
Toddh,
I think you may find the "11" in the prefix also stands for the type of top connection the plug has.
We need the threaded screw on type top to the plug with the removable cap & the "11" is a FIXED type cap that cannot be removed, so cannot be used with the standard plug caps.
I fell into this trap buying NGK plugs a few years ago.
This is why plugs with "11" in the prefix are normally cheaper than ones without
Regards
Pete F
Regards
Pete F
Last edit: 12 years 3 months ago by strate6.
- tackelhappy
Re: SPARK PLUGS ?
Great work gents, thanks
OKANAGAN FALLS. BC ,Canada
- Toddh
Re: SPARK PLUGS ?
12 years 3 months agostrate6 wrote: Toddh,
Regards
Pete F
Good to know Pete.
When you go to NGK's website, I did not see that distinction in their literature. when you see the picture, you can see the black permanent top cap vs the removable threaded cap.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Moderators: scotch
