kz1300 banner
Automotive Equivalent for Thermostat
  • rdurost
  • rdurost's Avatar Topic Author
  • Elite Member
  • Elite Member
6 years 4 months ago
#25814
What's the automotive equivalent of an '82 KZ1300 thermostat? There's an old topic that says it's a Mitsubishi Eclipse, 2006-2009, but the flange diameter is wrong. I believe it should be 2" diameter, and the Mitsubishi is 2.2".
Thanks.
Richard
  • Bucko
  • Bucko's Avatar
Re: Automotive Equivalent for Thermostat
#25839
Not sure if I'm thinking of the 1300 thermostat or not but there was a thread I read where the poster ground down the outer edge of the automotive thermostat to the required dia
  • dcarver220b
  • dcarver220b's Avatar
#25846
Be careful. Remember OEM tstat has two modes... warmup and normal, a 2-stage thermostat. I found a replacement that claimed to be OEM correct but it wasn't.. Single vs. dual stage. So the motor overheated.
  • Bucko
  • Bucko's Avatar
#25847
dcarver220b wrote: Be careful. Remember OEM tstat has two modes... warmup and normal, .
Isn't that how every thermostat works?
  • rdurost
  • Elite Member
  • Elite Member
5 years 9 months ago
#27810
(I know I'm resurrecting an old post, but...)
Not necessarily. For example the Cadillac 472/500 engines use a thermostat that has an extension on the bottom that moves with the main "valve," so when the engine is stone cold, the extension blocks a port under the thermostat, and 100% of the water goes right back to the engine so it warms up more quickly. I think that's what the "dual mode" thing is about.
  • strate6
  • strate6's Avatar
#27818
The following user(s) said Thank You: Bucko
Moderators: scotch
Time to create page: 0.159 seconds
