Oil Drain Valve. Stahlbus.
- strate6
6 years 1 month ago - 6 years 1 month ago
Has anyone out there had any experience with their 1300 with this product (or similar) ?
In principle, it looks to be good idea / solution.
www.stahlbus.com/info/en/products/oil-drain-valves
As the sump (oil pan) plug on many 1300's is forward facing, it will not make it impractical on a length or protrusion basis (as it would with a DOWN facing plug).
Pete F
UK
Pete F
UK
Last edit: 6 years 1 month ago by strate6.
- stocktoy
Re: Oil Drain Valve. Stahlbus.
6 years 1 month ago
I have used a similar type at work on our construction and dump trucks because of hyd hoses interference and they work great however they all have downward facing drain plugs.
Moderators: scotch
Time to create page: 0.163 seconds
