kz1300 banner
Water temperature sensor thread diameter and pitch
  • McBoney
  • McBoney's Avatar Topic Author
6 years 6 days ago
#27040
Hi all,
I am getting myself an Acewell speedo and it comes with a temp gauge, but that needs to have its own sensor to get the right readings. So the original one needs to come out and a new one needs to go in.
I have measured the sensor thread and it is 16mm diameter, but does anyone know the pitch? My manual vernier is not accurate enough to measure this....
Cheers
Paul
Six-Pot-Cafe in the making...
  • biltonjim
  • biltonjim's Avatar
Re: Water temperature sensor thread diameter and pitch
6 years 6 days ago
#27044
According to page 39 of the manual, it is 16 x 1.5 Paul.
The following user(s) said Thank You: McBoney
  • McBoney
6 years 6 days ago
#27046
Ah, you found it!! I went through the manual twice and missed it. Thank you!!
Paul
  • Bucko
  • Bucko's Avatar
6 years 6 days ago - 6 years 6 days ago
#27047
May not be worth the effort but if you're taking the OEM sensor out anyway, you could pop the old and the new into water of various temperatures, measure the resistances, and see how much different they are - might be able to cheat by adding some resistance either in series or parallel.
Last edit: 6 years 6 days ago by Bucko.
  • Phil
  • Phil's Avatar
6 years 5 days ago
#27048
Bucko wrote: May not be worth the effort but if you're taking the OEM sensor out anyway, you could pop the old and the new into water of various temperatures, measure the resistances, and see how much different they are - might be able to cheat by adding some resistance either in series or parallel.
You can select the input range on the Acewell anyway iirc the original sender is 0 to 100 ohms? I opted to use their sender anyway, with a brass adaptor.
  • McBoney
6 years 5 days ago
#27049
I'll stick with theirs as then if it doesn't work for some reason its not my fault..
Moderators: scotch
Time to create page: 0.177 seconds
