kz1300 banner
"The small boxes just after the collectors" - What's the Proper Name?
  • rdurost
  • rdurost's Avatar Topic Author
  • Elite Member
  • Elite Member
5 years 4 months ago
#28251
What are they called, and has anybody ever cut one open to see what's inside?
Thanks!
Richard
  • biltonjim
  • biltonjim's Avatar
Re: "The small boxes just after the collectors" - What's the Proper Name?
#28252
Maybe Lare could chime in here. I recall he mentioned these parts when he showed us the superb stainless exhaust systems which his friend Ari manufactured. His systems used his own design of collectors.
  • scotch
  • scotch's Avatar
#28253
"Resonators"
Always High - Know Fear !
  • rdurost
  • Elite Member
  • Elite Member
#28255
That could certainly be what Kawasaki called them, but the only use of the term I'm familiar with is the straight-through, fiberglass-packed "Cherry Bomb" style mufflers used near the end of the tailpipes on American cars in addition to chambered main mufflers. I think they may have been there to stop the "drone" (exhaust system resonance).
  • LareNurminen
  • LareNurminen's Avatar
#28266
I do not know what they should be called. Kawasaki spare part book calls them "muffler complete". This refers to the nr 1 or nr 6 downpipe with the integrated middle muffler.
Aris solution was to make the downpipes into units with 3-1 collectors. These are connected together with a balancing pipe which also works as a muffler. The balancing pipe then connects to the original mufflers.
Aris son in law, also stainless pro, is re-starting production under Aris guidance so the stainless versions will be available in the future.
The following user(s) said Thank You: biltonjim, rdurost
  • Phil
  • Phil's Avatar
  • 1984 ZG1300-A1 DFI
#28267
Power chambers or expansion chambers? In the dim & distant past I seem to recall someone cutting them open & reporting them being empty, save for the outlet pipe which entered the box & did a 90 degree bend with an open end inside the box.
The following user(s) said Thank You: rdurost
Moderators: scotch
Time to create page: 0.185 seconds
