kz1300 banner
Considering electric fan to replace OEM
  • dcarver220b
  • dcarver220b's Avatar Topic Author
4 years 10 months ago
#29430
Still trying to cool the old gurl down. 1979 A1.
Found this , but no longer available.
Which got me thinking about electric fans..
Has anyone grafted on a newer better aftermarket universal electric fan?
Words of Wisdom?
  • Kawboy
  • Kawboy's Avatar
Re: Considering electric fan to replace OEM
4 years 10 months ago - 4 years 10 months ago
#29431
My 2 cents-
I don't believe the issue is with the rad fan. If anything, a partially blocked rad or possibly the coolant system needs burping which has been a long standing issue.
I did a mod for shits and giggles using a ran fan from a ZRX1200 which happens to be a 7 blade version of our 4 blade fan. Testing revealed an increase of airflow of about 30%. Did I need to do it- probably not but me being me I chose to exercise my abilities and do the mod.
Here's a listing for a  zrx 1200 rad fan on EBay
and a link to my fan shroud mod   Kawboy's Restoration      starting at post #7951 and follow through for the next 2 pages for the final result
Last edit: 4 years 10 months ago by Kawboy.
The following user(s) said Thank You: dcarver220b
  • sparkee09
  • sparkee09's Avatar
  • Junior Member
  • Junior Member
#29434
what temps are you riding in? its been over 100 degrees like the last 2 weeks here, i tried burping my system forever to make sure it was working good, maybe it does need a good cleaning, but my voyager typically runs 1 to 2 bars past the center, and i'll usually see it go to 3 bars past a few times during riding but its usually not there very long. I'd like it to run cooler, but part of me thinks its the crazy heat and it wont do better till things cool off
  • dcarver220b
#29444
Thanks for reply guys. Yes, the system has been fully burped several times. Kawboy, regarding fan, I agree, just looking to make small improvements until the smoking gun is found.
Did some good work yesterday
Clicky Me
Last edit: 4 years 10 months ago by dcarver220b. Reason: Fixed broken link
  • dcarver220b
#29453
My 2 cents-
Thanks for the idea Kawboy. Ordered one from eBay, and the neighbor is handy with welders... :)
Moderators: scotch
Time to create page: 0.266 seconds
