kz1300 banner
Tachometer not responsive
  • Badger
  • Badger's Avatar Topic Author
4 years 5 months ago
#30055
Had problems with the 1981 speedometer cluster after taking a spill a few months back. After installing the tachometer it became slow to respond to engine revs. Reads about right at an idle but wont respond to throttle revs. Any and all advice is welcome in advance.
Happy New Year to all.
  • scotch
  • scotch's Avatar
Re: Tachometer not responsive
#30056
Sorry to hear about your "spill".
Don't know how bad this "spill" was.......doubtful that the tach. frame got damaged, so would focus on giving the internals a good cleaning. Old lube, dust and insects will cause this scenario.
  DO NOT use high pressure air !  You'll ruin the Hair-spring" !
  Electronic Cleaner in an aerosol can and WITH and Extension Tube  is effective and safer as you can precisely control it's application..  The only lube required would be a drop of oil on the input bushing.  Don't lube anything else !   (This applies to the Speedo in particular) .  When clean, there is no load on any of the internals. Over lubing will just attract dust and grime.
hope this works out for you !
Always High - Know Fear !
The following user(s) said Thank You: dcarver220b
  • dcarver220b
  • dcarver220b's Avatar
4 years 4 months ago
#30063
I've used these guys 2x times for kz1300 speedo's and 1x for Honda Accord speedo. They do great work, and do tachometers too.
www.foreignspeedoinc.com
  • Gavin
  • Gavin's Avatar
  • Premium Member
  • Premium Member
#30065
I would try a new cable first off, the ends are squared to fit the drive if rounded off with use the cable can slip
when under excessive load
Moderators: scotch
