Waterpump mechanical seal.
- zed_thirteen
Re: ZN1300 Rad Hose
3 years 2 weeks agoI purchased stainless jubilee/worm type hose clamps. I've had the radiator off a couple of times and the bottom one did start leaking so I had to replace it - so perhaps there is a problem?I'm still following up in this. I think I've found a suitable hose, but I've read some stuff on silicone hoses needing special clamps. Did you reuse the OEM clamps?I got mine from autosiliconehoses.com (£7.86 + £3.25 shipping):Silicone Polyester Reinforced Hose - 32mm - 45 Degree Elbows - 15 ColoursSKU: P SSE 045 032 KColourBlack
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
The following user(s) said Thank You: Bucko
- Bucko
Re: Waterpump mechanical seal.
2 years 11 months ago
I installed a new hose, but only the bottom one as the inside of the hose was a bit ratty from the curd that had built up on the lower rad spigot. The top hose was in excelling shape so I reused it. Also reused all hose clamps, which were all in like-new condition.
Moderators: scotch
Time to create page: 0.166 seconds
