kz1300 banner
Waterpump mechanical seal.
  • Bucko
  • Bucko's Avatar Topic Author
ZN1300 Rad Hose
3 years 10 months ago
#30561
Not sure the ZN1300 and the KZ1300 use the same rad hose - the part numbers are different - but I'm curious, since the OEM hoses are NLA, what hoses are you guys chopping up to work with your KZ1300's?
  • zed_thirteen
  • zed_thirteen's Avatar
Re: ZN1300 Rad Hose
#30563
I bought an off the shelf silicone hose with a 135° bend and a straight silicone hose.  As it turns out there was plenty left over after cutting the top hose to make the bottom hose
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • Bucko
Re: ZN1300 Rad Hose
#30566
Any chance you have a part number or fitment list for the hose you used?
  • scotch
  • scotch's Avatar
Re: ZN1300 Rad Hose
#30567
Always High - Know Fear !
The following user(s) said Thank You: Bucko
  • zed_thirteen
Re: ZN1300 Rad Hose
#30569
I got mine from autosiliconehoses.com (£7.86 + £3.25 shipping):Silicone Polyester Reinforced Hose - 32mm - 45 Degree Elbows - 15 ColoursSKU: P SSE 045 032 KColourBlack
1980 CBX1000-A
1990 ZZ-R1100 C1
  • Bucko
Re: ZN1300 Rad Hose
3 years 3 weeks ago - 3 years 3 weeks ago
#31275
I'm still following up in this.  I think I've found a suitable hose, but I've read some stuff on silicone hoses needing special clamps.  Did you reuse the OEM clamps?
Last edit: 3 years 3 weeks ago by Bucko.
Moderators: scotch
Time to create page: 0.181 seconds
