Oil Seepage
- dcarver220b
Oil Seepage
2 years 4 months ago
2024-01-20 Oil SeepageWhat's behind this cover? Anything going to spring out?
Partzilla doesn't show a gasket for it...
Can these tensioners be removed for new gasket or is there danger of slipping a tooth?
Hopefully not a base gasket leak.
x
x
- Kawboy
Re: Oil Seepage
2 years 4 months ago - 2 years 4 months ago
Item #33 - 45mm o ring behind the timing shaft cover (which is the access for removing the timing shaft sprocket). Just crankcase pressure .if you have to remove the tensioners do so very carefully and don't move the crankshaft until the tensioners are back in and confirm the camshaft timing before turning over the engine.
Last edit: 2 years 4 months ago by Kawboy.
The following user(s) said Thank You: dcarver220b
- dcarver220b
Re: Oil Seepage
"Engine Covers" department.
O-Ring ordered. eBay.
Tensioners. I have to pull valve cover due to leaky end cap. Lesson learned. Buy OEM when you can. These were re-pops. Will disconnect battery and not rotate crankshaft.
Anything to check on the other tensioner?
Thank you, once again
Don
Don
- Kawboy
Re: Oil Seepage
2 years 4 months agoThe only thing that could happen if the other chain jumps a tooth the ignition timing will be off but that chain is so short I doubt it will jump. the tensioner on that chain is more about limiting the possible + - ignition changes.Anything to check on the other tensioner?
- scotch
Re: Oil Seepage Cam Cover end-plugs
This solved my weeping issues MANY years ago. This "Pipe Fitters" tape is much thicker than standard "Teflon" tape.
Always High - Know Fear !
Last edit: 2 years 4 months ago by scotch.
- dcarver220b
Well, that's a great idea! Thanks. I hate to pull the valve cover again.. but I hate leaks even more.
I'm not sure if Ray replaced o-rings when reassembling but I doubt it, given the current issues.
Moderators: scotch
Time to create page: 0.181 seconds
