kz1300 banner
Rick's MotoSport Electric KZ1300 starter 61-205
  • dcarver220b
  • dcarver220b's Avatar Topic Author
2 years 7 months ago - 2 years 7 months ago
#32141
Just thought I'd share. Copied and pasted from here .
2024-01-26 Install new  Rick's Starter This thread a spin-off from this one. To start at beginning, click here.Ok screw it. Here's that post repeated.Corroded nut on starter cable. Connection was clean, however.
[img
Out of the hole and cleaned up.
[img
OEM starter. 60 amps initial, 30 amps running, unloaded. New one from Rick's Electro ordered.
[img
Last edit: 2 years 7 months ago by dcarver220b.
  • dcarver220b
Re: Rick's MotoSport Electric KZ1300 starter 61-205
#32142
O-Ring shape? Looks flat. Need to see if Rick's comes w O-Ring or not.
[img
Back to original programming. Box arrived in pretty good shape.
[img
x
[img
Except for this gouge.
[img
Yep, the lug post gouged through.
[img
x
[img
  • dcarver220b
#32143
Purty enough..On bench, ~45 amp initial draw then down to 30. Unloaded of course.
[img
Then issues. The positive terminal is reversed on Rick's.
[img
Making it hard to install cable once motor installed.
[img
Off to Rick's Rodeo. Loosened cable from solenoid, brought up extra slack, reversed direction, installed cable, tried to stab motor.. Very tight fit and no longer 'road serviceable.
[img
[img
  • dcarver220b
#32144
But I got it in there. Going to email/call Ricks and see what's up.Did notice they have two different motors available...
  1. New OEM Style Kawasaki Stator 21_245
  2. New Kawasaki Starter Motor 61_205
I went for option one thinking it would be a 'direct replacement.Will update results from Rick's response..
  • tackelhappy
  • tackelhappy's Avatar
#32165
So, are you talkiing about a starter motor or a Stator ?
OKANAGAN FALLS. BC ,Canada
  • dcarver220b
#32166
Starter motor. To spin the crankshaft to start.
Moderators: scotch
Time to create page: 0.171 seconds
