kz1300 banner
Valve Adjustment Bias Error?
  • dcarver220b
  • dcarver220b's Avatar Topic Author
2 years 4 months ago - 2 years 4 months ago
#32179
Last March did a valve  adjust . Later discovered slight oil leak from valve cover cap.Removed cover. Thought I'd QC my work and re-measure clearances.
Sure as sh$t, 3 measure LOOSE. WTFO?I was soo careful to follow the FSM to the letter. Checked and double-checked?
So what happened? How was this error introduced?
  • ​Could it be that after 30 minutes of running, things 'settled' in to allow more clearance? Which led to this consideration.
  • I routinely add engine oil to the bucket via a syringe. Is it possible that, in certain cases, the oil is 'trapped' in the bucket, creating a 'wedge' resulting in clearance reduction which in turn is increased by installing a thinner shim? Then, after some run time, the oil gets squished out, the clearance increase?
Just wondering about things on a rainy day...
Last edit: 2 years 4 months ago by dcarver220b.
Moderators: scotch
Time to create page: 0.160 seconds
