kz1300 banner
Regrettable Engine strip down !!!! I think
  • z13phil
  • z13phil's Avatar Topic Author
Re: Regrettable Engine strip down !!!! I think
10 months 6 days ago - 10 months 6 days ago
#33951
I measured the original valve in the lathe, with a dial gauge. But not measuring the stem ! i only measured the widest part of the valve head. This was about 1mm out in the circumference measurement. Then decided to buy a new valve. Saying that before the strip. #6 was making 135psi
Last edit: 10 months 6 days ago by z13phil. Reason: spelling mistake
  • Kawboy
  • Kawboy's Avatar
#33952
That explains the oddity. Measuring on the circumference may not be a true reading since that surface was not a machined surface to begin with. I use a " Last word indicator" and indicate off of the sealing face of the valve.
The following user(s) said Thank You: z13phil
Moderators: scotch
Time to create page: 0.236 seconds
