Regrettable Engine strip down !!!! I think
- z13phil
Re: Regrettable Engine strip down !!!! I think
1 year 1 month ago
Hi Kawboy, just a few things to go over !
I have removed the head, Inlet valve bent. Exhaust was also leaking so i will replace this one also. I have no idea how this has happened, I took utmost care when doing this.
Ok the head gasket looks good, you also mentioned gasket sealant ? I have not used any sealant, should I be using any ?
Could this problem be caused by slack in the cam chain, or a stretched chain ? If so when installing the cams where should I take the slack out of the cam chain. Would this be the exhaust cam side or the inlet side ?
As you say, this problem is not mentioned in the official workshop manual !!! would I be able to check for this problem before turning that rotor for the first time !
Again many thanks for your help on this situation Im in.
- Kawboy
1 year 1 month agoHi Kawboy, just a few things to go over !
If you're using the original OEM head gasket which has sealant around the water jacket ports and oil ports then you could install the gasket dry. That being said, it wouldn't hurt to use a light coating of an appropriate head gasket sealer.
You're experience here has probably got you gun shy, so let's dive in just a bit.
As per the manual, the first thing to do is install the exhaust cam. When doing this. at this point, all the inlet valves are seated so nothing bad can happen yet. Install the exhaust cam and torque down the cam bearing caps.
Now time the exhaust cam. Ensure the crankshaft is located with the "T" mark at the front crankcase cover. Pull the cam chain up at the front and engage the chain with the cam ensuring the timing mark on the camshaft is located at the half joint cylinder head cover. At this point the exhaust cam is completely installed and timed.
Next the manual talks about placing the intake cam in position and timing it first before tightening down the cam bearing caps by counting the 17 links and engaging the timing chain with the intake cam. The manual also mentions that you will have to rotate the crankshaft clockwise just enough to set the intake camshaft in the bearing journals. Note that when rotating the crank clockwise, the exhaust cam will also rotate. During this part of the installation, the cam chain should be tight between the exhaust cam and the secondary shaft and tight between the intake and exhaust camshaft. All the slack should be at the rear of the engine which is where the cam chain tensioner takes care of the slack. Tighten down torque the intake cam bearing caps.
In all fairness the manual does state NOTE: Do not allow the chain to loosen even for a moment during camshaft installation mentioned below. This is the critical point in camshaft chain II timing. Although they could have emphasized this better with bold text
Again many thanks for your help on this situation I'm in.
Once you have the tensioner installed, you could rotate the crank clockwise maybe 10 to 20 degrees and look at the chain down near the tensioner and see if the chain is slack, then rotate the crank shaft counter clockwise and see if any slack is present at the front of the engine between the exhaust cam and the secondary sprocket. there shouldn't be any to speak of.
The following user(s) said Thank You: z13phil
- z13phil
1 year 1 month ago
Kawboy, #6 inlet valve I changed to a new valve as i took the head off, i checked it in the lathe and found it to be slightly bent but it was seating OK. How close do these valves get to the piston ?
I feel more confident now. Thanks for sharing your knowlage .
- Kawboy
1 year 1 month ago
i don't know how a valve could be "slightly bent" yet sealing OK. That doesn't make any sense.
As far as piston to valve clearance - a good rule of thumb is 2mm - 2.5mm which will allow for timing chain stretch over time, carbon build up on the piston crown and valve heads, and valve float at high RPM
- dcarver220b
1 year 1 month ago
I've had my 79 A1 exhaust cam 1 tooth out and no valve train damage..
- z13phil
1 year 1 month ago
So was this counting 17 links in the cam chain. So do you know if it was the cam or cams out. Or the chain in the wrong position ?
Moderators: scotch
Time to create page: 0.161 seconds
