kz1300 banner
Cam chain tension
  • coleface
  • coleface's Avatar Topic Author
  • Senior Member
  • Senior Member
Cam chain tension
1 year 1 week ago
#34012
After about a 2 year hiatus I'm back finishing the valve adjustment. At the start of this work I pulled the head to check valves and changed the 2 plastic cam chain gears with the steel ones. My question is should the cam chain running over the camshaft be quite tight?  Thanks
  • scotch
  • scotch's Avatar
Re: Cam chain tension
1 year 1 week ago
#34013
".....should the cam chain running over the camshaft be quite tight?
Yes.  There should be no "slack" in the chain between the cam-shaft sprockets.
Always High - Know Fear !
  • coleface
  • Senior Member
  • Senior Member
1 year 1 week ago
#34014
Thank you, I'm pretty sure I followed the book when assembling it but like i said after a 2 year away period I sort of forget what I did. I hope to get the 2 valve shims soon and get the engine back together end fired up.
Moderators: scotch
Time to create page: 0.158 seconds
