kz1300 banner
86 DFI Technical information
  • Roderick
  • Roderick's Avatar Topic Author
  • New Member
  • New Member
1 month 1 week ago
#34975
Hello everyone,
I am trying to help out a friend. His 86 DFI runs really bad.
I would like to check the engine timing and the ignition timing.
As I own a 80 Carburated version I do not have the workshop manual of a DFI version.
Is there someone that could share the workshop manual of a 86 DFI or the pages of the workshop manual where engine timing and ignition timing is explained?
Thanks in Advance!
  • Kawboy
  • Kawboy's Avatar
Re: 86 DFI Technical information
1 month 1 week ago
#34976
It's available to download free from the bottom of the " Forum" tab. You have to be logged in to see it.
KB
The following user(s) said Thank You: Roderick
  • Roderick
  • New Member
  • New Member
1 month 1 week ago
#34977
Thank you, I did not see that.
  • Roderick
  • New Member
  • New Member
1 month 1 week ago
#34978
I do try to open the file : KSM-Z1300&KZ1300 (A1thruA5) but it keeps staying at 100% and does not show the file. Do you experience the same?
  • dcarver220b
  • dcarver220b's Avatar
1 month 1 week ago
#34979
It opened for me. Try another browser?
  • Roderick
  • New Member
  • New Member
1 month 1 week ago - 1 month 1 week ago
#34983
Yes at a other browser it worked thank you.
I see in the file is a wiring diagram for 80,81,82,83 these are all pre DFI. Is there someone with the DFI wiring diagram and maybe the measuring values of the Pick up coils, ignition coils primary and secondary?
Or is it known that the value's should be the same? of the resistance measurements?
Last edit: 1 month 1 week ago by Roderick.
Moderators: scotch
Time to create page: 0.135 seconds
