86 DFI Technical information
- Roderick
- New Member
1 month 1 week ago
Hello everyone,
I am trying to help out a friend. His 86 DFI runs really bad.
I would like to check the engine timing and the ignition timing.
As I own a 80 Carburated version I do not have the workshop manual of a DFI version.
Is there someone that could share the workshop manual of a 86 DFI or the pages of the workshop manual where engine timing and ignition timing is explained?
Thanks in Advance!
Thanks in Advance!
- Kawboy
Re: 86 DFI Technical information
1 month 1 week ago
It's available to download free from the bottom of the " Forum" tab. You have to be logged in to see it.
KB
KB
The following user(s) said Thank You: Roderick
- Roderick
- New Member
- Roderick
- New Member
1 month 1 week ago
I do try to open the file : KSM-Z1300&KZ1300 (A1thruA5) but it keeps staying at 100% and does not show the file. Do you experience the same?
- dcarver220b
1 month 1 week agoIt opened for me. Try another browser?I do try to open the file : KSM-Z1300&KZ1300 (A1thruA5) but it keeps staying at 100% and does not show the file. Do you experience the same?
- Roderick
- New Member
1 month 1 week ago - 1 month 1 week ago
Yes at a other browser it worked thank you.
I see in the file is a wiring diagram for 80,81,82,83 these are all pre DFI. Is there someone with the DFI wiring diagram and maybe the measuring values of the Pick up coils, ignition coils primary and secondary?
Or is it known that the value's should be the same? of the resistance measurements?
Last edit: 1 month 1 week ago by Roderick.
Moderators: scotch
Time to create page: 0.155 seconds
