Remove connecting rods without splitting cases?
- bobber-edd
11 years 7 months ago - 11 years 7 months ago
Is it possible the remove the con rods by removing the sump only or do you have to split the engine case ??
zed 13 1979 A1 model
Last edit: 11 years 7 months ago by KZQ.
- Tyler
- Elite Member
Re: Remove connecting rods without splitting cases?
no, the oil pan is behind the crank, there isn't enough room to reach in and get at the rod caps. Time to split the cases...
1981 KZ1300
The following user(s) said Thank You: bobber-edd
- bobber-edd
how do i do that ?? is from underneath where all the bolts are ??is there a gasket or glue ?
- KZQ
- Administrator
11 years 7 months agobobber-edd wrote: how do i do that ?? is from underneath where all the bolts are ??is there a gasket or glue ?
The first step is to download the service manual from the box at the right.
Bill
Moderators: scotch
Time to create page: 0.173 seconds
