Engine paint/laquer
- charlie9670
- Elite Member
Engine paint/laquer
10 years 1 month ago - 10 years 1 month agoI've sprayed a coat of high temp paint on the engine while I had parts stripped off, I'm thinking it won't be very hard wearing and would last longer with a coat of engine laquer over the top, does this seem like a good idea
Last edit: 10 years 1 month ago by charlie9670.
- Ledkz1300
Re: Engine paint/laquer
I don't know anything about paint but it sure looks purdy
- Tyler
- Elite Member
I don't know of a clear coat that will take temperature, I'm sure they are out there but its probably a specialty product.
The enamel paint will harded significantly when you heat up the engine. Rock chips are going to happen, don't worry too much about that stuff.
1981 KZ1300
- charlie9670
- Elite Member
I put a coat of lacquer on, found some the same make as the paint, time will tell how it lasts but it looks nicer with a bit of a shine and should deter petrol and oil a bit from staining.
- charlie9670
- Elite Member
Painted the wheels satin black while I was at it, bit of a meaner look I think. I had to sand what I could down of the peeled chrome on the engine covers to get them flat-ish, best I could do for now without time and money.
- paulb
- Elite Member
Hi
did you paint it in position or while it was out of the frame either way it looks great
Paulb
Paulb
Time to create page: 0.187 seconds
