kz1300 banner
Markland Backrest
  • samchar12
  • samchar12's Avatar Topic Author
  • New Member
  • New Member
Markland Backrest
12 years 1 month ago - 12 years 1 month ago
#3364
I am in the process of putting a 1988 ZN1300 back together and wanted to know if anyone had any information on how to mount the markland backrest?
I have a pretty good idea where it goes, but wanted to see if there were any instructions out there so I know if I need any new bolts or anything.
Thanks.
Last edit: 12 years 1 month ago by samchar12.
  • Toddh
  • Toddh's Avatar
Re: Markland Backrest
#3365
No eBay APP ID and/or Cert ID defined in Kunena configurationHello Sam:
It should mount to the tail end of the frame, and to the top two shock mounts. (you'll need to remove the tail piece to see those two mount points on the frame.
Is this the backrest in question:
If you could attach a photo, it would help.
Regards.
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Last edit: 12 years 1 month ago by Toddh.
  • samchar12
  • New Member
  • New Member
#3367
That is where I thought the mounts went. The entire rear section is off so the frame is readily accessible.
Mine is similar, but the padded section is larger and the arms have a pleather cover on them. It is also adjustable front and rear. I will try and get a couple of pictures if I can remember.
  • Toddh
  • Toddh's Avatar
#3368
My first thread is probably wrong, assuming we are talking about a Drivers backrest.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • samchar12
  • New Member
  • New Member
12 years 3 weeks ago
#3492
Here are some pictures of the backrest.
Time to create page: 0.163 seconds
