kz1300 banner
If you make pieces and parts or provide services for Kawasaki Sixes you may post links here to your business or product catalog. If you're just into 1300's and have found a business that you like to deal with post it up here.
CARB SERVICE uk?
  • classicnvintage1
  • classicnvintage1's Avatar Topic Author
  • New Member
  • New Member
CARB SERVICE uk?
8 years 4 months ago
#18726
Anyone recommended for KZ1300 carb servicing in the UK?
  • Haggler
  • Haggler's Avatar
  • Premium Member
  • Premium Member
Re: CARB SERVICE uk?
#18736
What sort of service are you looking for?
  • classicnvintage1
  • New Member
  • New Member
#18737
Thanks for responding. My carbs were running a bit rich, so took them off to ultrasonic clean them. The cleaning was reasonably successful but, the previous owner has bizarrely sealed each of the mixture screws in with a blob of what looks like epoxy putty on the tops of each one. I expect that will need drilling out and possibly new screws provided and the thing setting up. I don't mind doing the brutal bit, if I have to, but if the carbs survive I will need the necessary bits and then it set up correctly. It's not a trolley dolly bike, so not looking for polished metal!
  • Tonto
  • Tonto's Avatar
#18738
Contact "Oz" a call at Zed Parts in Bromsgrove: he really knows his stuff concerning Z13's and is very savvy when it comes to setting up / rebuilding carbs.
www.zed-parts.com/restorration-service
Cheers Tim
The following user(s) said Thank You: classicnvintage1
  • Phil
  • Phil's Avatar
#18739
Is it an American import? If I remember correctly the carb adjustment screw ports were filled with an anti-tampering glue for emissions reasons from the factory, although I'm not sure if that was for all states?
  • Haggler
  • Haggler's Avatar
  • Premium Member
  • Premium Member
#18740
Scotch has done good threads on carb cleaning and seeting. Just because the mixture screws are sealed doesn't mean you need new parts. Float heights seem to be really critical and the air drillings that bypass the throttle valves can block and no ammount of ultra sonic cleaning seems to rectify this. However Scotch has made a tool to do this which works brilliantly. Once back on I'd recommend using a colour tun to set mixture screws as the factory setting is not that good
The following user(s) said Thank You: scotch, classicnvintage1
Time to create page: 0.171 seconds
