kz1300 banner
If you make pieces and parts or provide services for Kawasaki Sixes you may post links here to your business or product catalog. If you're just into 1300's and have found a business that you like to deal with post it up here.
FUEL TAP / PETCOCK REPLACEMENT
  • strate6
  • strate6's Avatar Topic Author
  • On An Adventure Before Dementia ! !
12 years 1 month ago - 12 years 1 month ago
#2096
For those of us who need to replace or want to upgrade the standard fuel tap on our 1300/6 then by far the best NEW repalcement is the PINGLE Tap.
The important part of this is that the OUTLET faces inwards as the standard one does as there is no room on our bike for it to go either side of the tap itself.
With Pingle you need to fit a small adapter plate onto your tank first, then fit the tap itself.
Here is a list of what you need below
PINGLE TAP & ADAPTOR FOR Z1300/KZ1300
A1702C ADAPTOR
6211-AH Alloy Tap
OR..........
6211-CH Chrome Tap
Can be bought on Ebay or from Pingle stockists.
Pete F
Last edit: 12 years 1 month ago by strate6.
The following user(s) said Thank You: Bob4717, southpaw, robinson_m13
  • jamesdale44
  • jamesdale44's Avatar
  • New Member
  • New Member
Re: FUEL TAP / PETCOCK REPLACEMENT
11 years 2 months ago - 11 years 2 months ago
#6357
you can buy a tap from an kz1000 police bike,its a bolt on hook a vacuum hose to it and go I have three of them in use they are perfect.priced around $80.00 from kawasaki
Last edit: 11 years 2 months ago by jamesdale44. Reason: wrog spelling
Time to create page: 0.257 seconds
