If you make pieces and parts or provide services for Kawasaki Sixes you may post links here to your business or product catalog. If you're just into 1300's and have found a business that you like to deal with post it up here.
Valve adjustment
- Kawa2626
- New Member
Valve adjustment
4 years 10 months ago
Hi, I’ve been trying to get my 79 KZ1300 road worthy. Haven’t had any luck finding a mechanic familiar with the bike. Any help would be appreciated! Zip code 11782
- biltonjim
Re: Valve adjustment
Have you considered doing the work yourself with the aid of the factory service manual and the expert guidance available on this website?
- Kawa2626
- New Member
As a matter of fact I have considered it. I have the manual, new gasket and caps. I understand there is a special tool involved. Definitely would be would need help along the way.
Thanks,
Thanks,
- Kawa2626
- New Member
I did consider it. I have new gasket and caps. Isn’t a special tool involved, and are shims easily available?
Thanks
Thanks
- Kawboy
29mm valve shims
fit many makes and models range from 2.00mm - 3.10mm. Some dealerships used to offer shim swapping for a minimal price. Take them the shims you don't need and get the ones you do. Alternatively, keep the old ones for possible shim changing later and buy new ones for $9.00 a piece??
Valve shim adjusting tool $10.97 US plus shipping.
- Kawa2626
- New Member
4 years 9 months ago
When adjusting valves at the different crank positions do you do all the exhaust at one time and move crank and do all intake?
Time to create page: 0.169 seconds
