If you make pieces and parts or provide services for Kawasaki Sixes you may post links here to your business or product catalog. If you're just into 1300's and have found a business that you like to deal with post it up here.
Valve adjustment
- Kawa2626
- New Member
Valve adjustment
5 years 1 week ago
Hi, I’ve been trying to get my 79 KZ1300 road worthy. Haven’t had any luck finding a mechanic familiar with the bike. Any help would be appreciated! Zip code 11782
- biltonjim
Re: Valve adjustment
5 years 1 week ago
Have you considered doing the work yourself with the aid of the factory service manual and the expert guidance available on this website?
- Kawa2626
- New Member
5 years 1 week ago
As a matter of fact I have considered it. I have the manual, new gasket and caps. I understand there is a special tool involved. Definitely would be would need help along the way.
Thanks,
Thanks,
- Kawa2626
- New Member
5 years 1 week ago
I did consider it. I have new gasket and caps. Isn’t a special tool involved, and are shims easily available?
Thanks
Thanks
- Kawboy
5 years 1 week ago
29mm valve shims
fit many makes and models range from 2.00mm - 3.10mm. Some dealerships used to offer shim swapping for a minimal price. Take them the shims you don't need and get the ones you do. Alternatively, keep the old ones for possible shim changing later and buy new ones for $9.00 a piece??
Valve shim adjusting tool $10.97 US plus shipping.
- Kawa2626
- New Member
4 years 11 months ago
When adjusting valves at the different crank positions do you do all the exhaust at one time and move crank and do all intake?
Time to create page: 0.165 seconds
