kz1300 banner
If you make pieces and parts or provide services for Kawasaki Sixes you may post links here to your business or product catalog. If you're just into 1300's and have found a business that you like to deal with post it up here.
KZ1300 Fiche - crystal clear
  • dcarver220b
  • dcarver220b's Avatar Topic Author
2 years 6 months ago
#31812
Stumbled upon these while surfing the net.
Unlike fuzzy, low resolution exploded diagrams from partzilla, etc., these are crystal clear and very readable.
Hope it helps someone somewhere sometime.
The following user(s) said Thank You: roadhazard, Kawboy, Neville, Daro
  • Kawboy
  • Kawboy's Avatar
Re: KZ1300 Fiche - crystal clear
#31814
I still like Partzilla since once I find the part I'm looking for I can also find out which models also used the same part. Helps when you have to go shopping. Especially for things like a thermostat or oil pressure sensor. Partzilla will tell you all the different models, even those other than the KZ1300, which use that part.
  • dcarver220b
#31815
Every tool in the kz1300 box helps!
Time to create page: 0.171 seconds
