kz1300 banner
If you make pieces and parts or provide services for Kawasaki Sixes you may post links here to your business or product catalog. If you're just into 1300's and have found a business that you like to deal with post it up here.
OEM rubber parts brittle and hardened?
  • dcarver220b
  • dcarver220b's Avatar Topic Author
2 years 4 months ago
#32137
Recently did a valve adjust, then installed new gasket and caps on valve cover . One of the caps leaked, so here we go again. 2024-01-25 Remove Valve Cover, Install Timing Gear O-Ring
  1. Must remove both lower coils to remove valve cover
  2. It comes out RHS, keeping cover as far forward as possible
  3. Check cover end caps for brittleness I had OEM caps. The leaky one is rock hard, had no 'compression' left in it e.g. for the cover to squish the cap into the half-moon.
Recently received a batch of OEM end caps. This batch was 'good' and had compressibility.
Just another thing to watch for when dealing with 45 year old 'new' parts.
Time to create page: 0.165 seconds
