Use of BREMBO P4 front calipers
- Sofiabg89
- Junior Member
8 years 1 month ago
If anyone is interested of my creation, please let me know
Just to be bolted ON without cutting nor butchering your bike
They work with Brembo P4 with 65mm mounting bolt patern
I am selling each set of 2 adapter bracket for $200.00 +Shipping worldwide.
I have sold over 50 sets and I use them on some of my 26 KZ1300`s.
Contact me at 1300kawasakiman@gmail.com
- scotch
Re: Use of BREMBO P4 front calipers
8 years 1 month ago
Nice pieces ! You have to like CNC and the endless possibilities it provides !
Always High - Know Fear !
- Kawboy
8 years 1 month ago
Nice work !!
And now I know why there aren't a lot of KZ13's on the street. 26 of them all herded up on one farm. Do you have a sign at the end of your driveway saying "Polled Kawasaki's" ? (Hope you know this is in good jest. Not meaning to offend) I just can't resist an opportunity to make light of masses of Kaw's and herds of cattle.
- dmerc
- Junior Member
8 years 1 month ago
Do you have to use a different master cylinder with this conversion? And the big question, does this mod make a big difference?
- Dion
8 years 1 month ago
Graham from NZ used the caliper brackets as this guy is selling and some brembos off a Ducati, he kept the Z master cylinder and they worked, how well compared to using the matched Ducati master cylinder i cant advise.
the real answer to your question is you need the correct bore/stroke dimensions those calipers where designed for!
use the wrong cylinder and you could end up with either a very aggressive or under efficient set up.
you can find the 65mm four pot calipers on Ebay often with the master cylinder, Ducati or aprilia used on many of their bikes.
if going to a more efficient braking system i would advise you readdress your front suspension system set up to take full advantage of the extra braking power.
pics show the other way of fitting Brembos to the front forks, small amount of Tig and CNC work buy to me the end product is so much better and it can be reversed
Dion
Dion
The following user(s) said Thank You: DannyKZ, dmerc
- Kawboy
8 years 1 month ago
There's no getting around the fact that your TIG/CNC work on the fork to match up the Brembo's is a true "Work of Art" . For those of us who can do this kind of work, they are inspiring. But most of the members don't have the background to do this kind of work and the only viable option is for adaptor brackets and these brackets being offered are just the ticket. What's nice is that they are totally reversible if down the road the owner needs to sell the bike and the prospective buyer wants a stock machine.
Time to create page: 0.176 seconds
