side stand
- Jafsteph
side stand
5 years 9 months ago
Hi all finally got my bike off the bench put it on it's side stand and the lean was way over, just asking whats the standard length my side stand is 260mm from the centre of the bolt to the heel
- stocktoy
Re: side stand
5 years 9 months ago - 5 years 9 months ago
On one of my 1300's the side stand was loose in its mount and had been able to bend outward do to the bolt being loose if you can take it off put it in a vise and see if you can tighten up the gap of the pivoting end of the side stand. Unless the side stand has been bent deliberately for some reason?
Last edit: 5 years 9 months ago by stocktoy. Reason: more info
- Kawboy
Re: side stand
5 years 9 months ago - 5 years 9 months agoJafsteph wrote: Hi all finally got my bike off the bench put it on it's side stand and the lean was way over, just asking whats the standard length my side stand is 260mm from the centre of the bolt to the heel
I have a 1980 B2 and just measured the side stand for you. I get 290 mm from the center of the bolt to the middle of the foot. The bike is up on the main stand so it was easier to measure it that way. It should be easy to see if someone modified it since it's a cast steel item and there should be no smooth area as if it had been cut, welded and ground smooth.
Last edit: 5 years 9 months ago by Kawboy.
- scotch
Re: side stand
Bent (curved) side stands are easily straitened with some adequate heat. Early on mine ended up looking like it came off a Harley and allowed my bike to lean over, precariously! Straightened it and it's remained strait, ever since !
Always High - Know Fear !
- Jafsteph
Re: side stand
Thanks for the reply but from memory before i strip the bike down i forgotten it leaned to far over then and it was on the hit list to replace ,it's just the wrong one
Time to create page: 0.181 seconds
