Engine Guards for '82 KZ1300?
- rdurost
- Elite Member
5 years 9 months ago
Would engine guards for an '85 ZN1300 Voyager fit my A4?
- strate6
Re: Engine Guards for '82 KZ1300?
Should do as I believe Engine Mounting Points are in the same position on all 1300/6 models.??
Pete F
UK
Pete F
UK
- rdurost
- Elite Member
Unfortunately, it looks like the situation is even more muddled than I had feared. From an eBay offering of some $500(!) units from Italy:
"Will fit 79-80-81 model This set will not fit 82 model." Even different years of 1300 sport versions don't necessarily interchange!
I can't post eBay listings on here for some reason, but the item number is 164344282214 if you want to check it out.
- stocktoy
5 years 9 months ago - 5 years 9 months ago
does this work?
Nope I guess not
does this work?
Nope I guess not
Last edit: 5 years 9 months ago by stocktoy.
- Lucien-Harpress
I'm curious if it has to do with the different "stuff" Kawasaki decided to hang off the crankshaft at different points in the model run. I know the A3 had the ignition pickups in the right side, and certain later models added a second stator on the left (with an appropriately thicker sidecover to go over it).
- LareNurminen
The A1-A2-A3 versions of KZ1300 can be fitted with the same engine guards. A4 needs spacers on the left side to fit the "standard" guards. I have them on both of my A4s.
The European Z1300s can be fitted with standard guards.
The ignition model ZG1300 requires wider guards.
The following user(s) said Thank You: rdurost
Time to create page: 0.164 seconds
